Wanting to buy those Wiseco pisonts in the FS section, but the OP won't return my PM... This could be the determining factor in whether the MSP gets forged now or later...
bought a steedspeed... FINALLY
You'll love it. Biggest improvement from a single mod in my car, hands down. Makes it pull hard all the way to redline.
If it wasn't as heavy as the block I'd look for one.
<iframe width="420" height="315" src="http://www.youtube.com/embed/lX0MB7pJtKs" frameborder="0" allowfullscreen></iframe>
new 626 injector seals getting ordered hopefully tomorrow and I also have a lead on another AEM wideband to replace my stolen one for a shocking $50!! Hope that pulls through. If that works out, then my P.E.P. dp will get installed this weekend...or earlier depending on how I feel. Looking around to replace my cheap boost gauge with an AEM digital boost gauge. Hoping to find a deal on that too.
If it wasn't as heavy as the block I'd look for one. I know it's probably splitting hairs but still. Weight added is weight added. They do look pretty cool though.
I somehow opened a page from 03/27/12 and you said, "I drove the **** out of the car today" and I was like, "hell yeah, man! What fixed it?" Then I realized what date it was... LOL
Alright someone please help me with this one!
Had my exhaust manifold gasket, valve cover gasket, thermostat, and thermostat gasket replaced last week. No CEL showed up until about 50 miles afterwards. It was running fine until on my way home from school today and I noticed everytime I give it about half throttle it stumbled REALLY bad. Think it could be a bad o2 sensor or faulty spark plug or injector?
Ang input helps as I really don't want to **** it up any further.
They had the valve cover off, so they could have disturbed a failing ignition coil or wire... But don't start throwing parts at it!Just checked the WGA to make sure it wasn't building too much boost. Clip is still holding it on, and it's holding the pressure when I blow into the vacuum line. Should I start by replacing the o2 sensors, spark plugs, or fuel injectors?
If you have a P0134 that's for the front O2 which controls fuel mixture. If you're PCM is seeing no activity from it, most definitely start in that are. Make sure that it wasn't allowed to touch the manifold or anything else that could damage the wiring. If that seems intact, you can get really technical and I can provide you with a way to test it if you have an ohm meter. Otherwise, you can throw one on there. I've seen it happen that it was disturbed when removing the manifold to replace the gasket (happened to me in fact) in all likelihood, the O2 has failed.Well I checked the CEL and it came up with P0134, "Heated oxygen sensor H02S (RF) circuit no activity". First probably cause listed is an exhaust leak (which I doubt), faulty injector, engine mechanical condition, and faulty heated oxygen sensor. But I've also heard of people's spark plugs have caused the same symptoms.
If I even build a little boost, the car stumbles horribly. So much that I'm scared it'll blow the engine or something.
My brother thinks I'm crazy, and that unless I buy a Lotus Elise, or a Miata with Motons, not much else can handle better than the MSP. That's the thing. What if I buy another car, and it's not as good? I'd be kicking myself for parting it. IDK, I need to drive some other cars, I think.
Does it weigh more than the OE manifold?
