Installed Mazda MX6 Rear Strut bar
Installed AAC Sag-Be-Gone :)
Before
After
Yeah wanna make sure nothing I need
Now throwing two damn. Codes
P0103
Po113
Cleaned maf and ait sensor hope that works ..
i wonder how long i can last in CA without getting in trouble xD
i just finished putting this thing on (mild headache, but all my fault)
<a href="http://s789.photobucket.com/albums/yy176/freddy-ydderf/?action=view&current=0923122101_zps8a5545c7.jpg" target="_blank"><img src="http://i789.photobucket.com/albums/yy176/freddy-ydderf/0923122101_zps8a5545c7.jpg" border="0" alt="Uploaded from the Photobucket Android App"></a>
and no its not actually corksport, its racing beat, but i repainted it and i have about 10 corksport stickers that happen to fit perfectly
Who's p5 is this and do they ever figure that out? I've never seen this before.
http://www.youtube.com/watch?v=TpgmOBKVGFc
Whatever the cause is, it's allowing air to get into the system, which is causing the bubbling in the tank. You can see the bubbles rising from the bottom, where the hose is clamped on the nipple of the tank. I had a similar problem in my 3 caused by a pin-sized hole that developed in the tank and was shooting out a stream of coolant when it was filled above a certain level in the tank. So I'd say check all coolant lines for small leaks or cracks, check all clamps to ensure tightness, and if all else fails, replace the coolant tank.
I'm thinking bad radiator cap could cause this and it doens't appear to bad overflow jug in this guys car. I just ran across this video clip while searching proteges on youtube. I looked and their is no robo1000 on this forum at least.
installed new cx-6 antenna and my headunit just went blank and hazards dont work (blinkers still work) i replaced the fuses but still didnt work so i disconnected the battery for a few hours while i checked on here for a solution. connected the battery again and radio works but hazards dont. im guessing its the actual button but im gonna see if the radio goes out again. any advice is welcome :D
Finally got around to finishing up the plastidip on the car and fixed the front lip.
Also gonna change it up and do my roof black as well as the side mirrors.
<a href="http://www.flickr.com/photos/43150552@N02/8022467639/" title="IMG-20120924-00346 by David Dough, on Flickr"><img src="http://farm9.staticflickr.com/8169/8022467639_fa4603d986_z.jpg" width="640" height="480" alt="IMG-20120924-00346"></a>
