***Post your dropped 2's here!!**
The bumpstops on this car are part of the suspension, and the car rides on them even when stock. A bunch of the AutoX guys have done tests and proven that in hard cornering they're being hit quite a bit. Basically they're not like normal hard rubber bumpstops, they're made of a soft squishy material, and they basically make the suspension stiffer when you're cornering hard, but without making ride quality worse in normal driving. I personally don't plan on cutting them.
i agree with this,but with the H&R springs which are firmer you dont spend as much time on the bumps..so for me it helped but then again i dont autox
As soon as I can post pics on the forums I will. For now just look at my profile.
I'm running a 1 inch drop from Bilstein Coilovers. The car is sitting on BLACK 15X7.5 949racing wheels wrapped in 205/50/R15 Bridgestone Potenza RE-11's
bump for more pics.. come on.. a lot of you out there need to put your pics here!! lets see those coilover.. springs.. mazda b spec pics! post info on your drop wheel and tire size. less chatter more pics.
3 different wheel specs:
15x7.5 949 Racing 6UL's, 205/50 and 225/45/15 Nitto NT-01's, s*** load of a drop over stock, KSport coils, no rear threaded locking collars in the rear, H&R Camber Bolts with no camber (blame my former alignment guy)
IMG-20120806-00254 by CRG Racer24, on Flickr
15x7 ASA 5 Spokes +36 F, +31 R offset, Stock tires, Same Suspension setup as ^
IMG_6431 by CRG Racer24, on Flickr
IMG_6436 by CRG Racer24, on Flickr
IMG-20120705-00212 by CRG Racer24, on Flickr
And I'll get some pics of my new setup on the ASA's with 205/50/15 Falken Azenis RT-615's. Rubs like a b**** allllll the time at my ride height on stock fenders.
Racing Beat springs with 215/45-17's.:)
CUSTOMER HEAD LAMP 050.webpCUSTOMER HEAD LAMP 035.webpAUTOCROSS 030.webpAUTOCROSS 010.webp
Some flicks of my 2...H&R springs
mods:
FONT Motorsports: A/C Dials , Red stiched Shirter boot,
CorkSport: Front and rear sway bars, SRI, Crank Pulley, H&R springs
Goodwin: 949 Racing Lug nuts, Dog Bone Rear Mount, Braided Brake lines with Dot4 Blue Audi race fluid, Brembo front rotors
OEM Mazdaspeed3: Dead pedal, Door sills, front and rear headrest, oil cap from a gen 1 with a larger o-ring so that it would center, OEM antenna, Cobb Shift knob
OEM: rear bumper guard, all weather mats, intergrated Blue Tooth, Homelink Compass Mirror,
Misc: 4800k hi/low HIDs and 3000k h11 HID's in the fogs
I love the look of the asa's kinda leaning toward a set of slips my self...
