- 2002 Mazda Protege ES
How do I know if it got messed up? Oh and btw I'm using a spare egr valve bolt for bolt c since the bolt c snapped in half. Bolt B is 14mm right?
So that adjusts the belt tension? The belt feels over tightened. Trying to loosen it a little.
This is what I do. Use your index finger to FIRMLY press (not t0o hard but not t0o soft) on an open section of belt between two pulleys. If you get more than 1/4" of play, snug it up a bit.
