Maxx Mazda
Contributor
- Stock P5
Take the oil cooler off, get an extra nut, and thread the filter post further into the block.
On a daily driver is it good to and possible just to only do the mod on the pump and put it on ? Or you have to do the whole regulator stuff too and relocation of filter ?
You want to see 25psi at a warm idle and 10psi increase per 1000 rpm's
ok cool thanks. Can i go any higher or lower or does it have to be right at 25?
My oil pressure is usually 15-20 psi @ idle when warmed up. The lowest I have seen was about 12psi @ idle. My oil system is stock and I'm running 5w-30 Pennzoil Platinum and an 02 626 v6 K&N oil filter. I have an Autometer Ultra-lite II mechanical gauge tapped of the stock oil pressure sensor port.
