That won't happen lol
I'll be there. Do you plan to show up at the car show or just drive right by again?
Also another reason to not get Chinese tires. My bro found this on one of my other nankangs. Was on the inside.
damn man the guy i got those wheels from had those tires on for a long time with no problems =/
Put in one of my extra O2s and that seemed to fix the majority of the problems.
Got the smoke machine from the other shop and I had a small leak at the throttle body, from my vacuum source at the manfold, and #3 injector seal.
I still have a bit of a hesitation under load, but I think it's because my custom tune is for 12psi, and I'm only running 8psi...
Say it were a ZFR2F-11, that's an extremely "hot" plug, whereas a ZFR9F-11 would be extremely "cold"...
Can anyone tell me the advantage to running a Millenia S PCV valve?
had a day off so got some inspiration to use up the white vinyl left over, also got a quote for some powder coatings
here are the results so far:
got a MAF sensor on the way. Hopefully this fixes the issue and I can drive my car again. Haven't driven the car since the 12th. Starting to have boost withdrawals!!! WTH!!! lol
