From my understanding, those push button start kits still require the ignition to be turned on to work. The key would still be used to turn the ignition on, but instead of turning the key all the way forward to start the car you would use the push button instead.
Its exactly how the push button works in the S2000.
You know what else has a push button to start it?
My grill
Those things suck...the one in my grill died in no time.
most a AA battery operated and you just have to twist the base and the whole thing should pop out so you can replace the battery. Everyone is different though.
MSP related, I'll have my stock trunk and hood back on by the end of the weekend and I'll probably remove the lip lip too
Well so far today all I did was look at her and then walk right by her through the garage on my way to work :)
I personally enjoy turning my key when starting the car, i've driven some push to start cars and it just dosent feel right. Kind of like driving an automatic.. dosent feel right.
just pull the grounds out of the factory alarm and get a AutoZone switch.
There's a MS3 for sale locally thats tempting me, 08.5 with all the options. Miles are a little higher than I would like (55k). They're asking $16.5k. Had my heart set on an 06-07 Sti, but with anything under 50k, people are asking $25k+ it seems.
installed my new tails!
Back to stock hood & trunk
and cut a piece out of my grill so it can sit flush again
***Also, does anyone know what size bolts our license plate holes take for the trunk?
Will be finding out if a stick hood/cf hood will fit in my gf 2010 Mazda 3 hatch, so I can bring that cause it has cruise control and ac. And isn't nearly as loud lol. To get your hood and trunk that is.
I can tell you the trunk fits in the back seat of a protege no problem
o0n8, i like how you swapped the rear lip
I'm not a fan of it, about 3 months after I bought it I was rear ended and the 03 lip was the one the shop could find.
