CX-9 Bose Speaker sizes?
So the factory 5 tweeters are not changed? Did you double the output to the tweeters from the BOSE amp?
And you added two more amps - one for the four door speakers and one for the sub?
Which enclosure do you use for the added sub?
Eager to see the photos!!!
ok I finally upgraded my whole system
i kept the Bose factory 10 channel amp, this is running the 5 factory tweeters
I upgraded the following
front doors with Cadence FX8M4 (4 ohm) 8" 250 Watt MidBass Driver Midrange Car Speakers
http://www.ebay.com/itm/ws/eBayISAPI.dll?ViewItem&item=350524359506&ssPageName=ADME:L:OU:US:1123
Rear Doors
Cadence XM-68HC Xenith 6.5" 300 Watt 8 Ohm Loud Mid Range Car Audio Speakers
http://www.ebay.com/itm/ws/eBayISAPI.dll?ViewItem&item=300662719691&ssPageName=ADME:L:OU:US:1123
I powered these with Rockford Fosgate PBR300x4
I have Brutus BRZ1700.1D and Rockford Fosgate T1D212
I removed the Bose sub and put the 2nd Battery where the Bose used to be.
I'll take some pictures later on and post it here
sorry been busy, here's some pictures, i actually upgraded to 2 Skar VVX 15"
Hi Supradupe, you replaced your front 3.5" speakers with the infinity kappa 3.5"; do they fit without any modifications? Is the tweeter protruding too much that you cannot place the cover back on? How about the dongle, i.e., external crossover, do you have a place for it? Thanks.
I replced the head unit with a Pioneer Avic 120bt, this was my first upgrade
