keegan0103
- 2003 Spicy Orange MSP
Hey guys, I just bought a 2003 MSP with about 89k on it. Since then ive done my share of searching and whatnot for the small problems that the car has in regards to drivability.
Mods: Poorly innstalled 2channel j&s safeguard
Custom fmic with hardpipes and VTA hks ssqv
blitz electronic boost controller
injen CAI
Divided 3 inch downpipe
3 inch full catless exhaust (no o2 spacer)
Heres the issue(s)
When you first start the car, it requires a occasional blip of the throttle to not die. When it finally allows itself to idle, it sounds like it has a VERY agressive set of cams. pulle maybe 10 inches of vacuum.
Once warmed up, car idles at ~12-14 inches of vac, no more camming
However engine braking pulls 20 inches of vac
Ive checked for vac leaks by spraying vac lines and/or capping off lines. NO changes
the knockguard was missing the o2 clamp, and the gauge never worked. Sorted out all the wiring (used the o2 clamp option) and was upset to see that once the rear 02 (which feeds the gauge) once warmed up, would read totally rich any time the gas was pressed. Car never goes into closed loop operation.
Light throttle in vac it drives fine, but once you begin the transistion into boost under light or medium throttle the car feels like its pulling LOTS of timing, almost to the point where it wants to start sputtering, while AFR gauge is pegged rich/
When at wot, power delivery is random and sporatic all throughout the rev range, and will actively gain and loose power while my foots in the floor
Codes for front 02 no signal
random misfire (due to idle)
injen CAI
Heres the issue(s)
