Moderately large update!
I got a bunch of parts in Friday. More on those later...
I got the fuel pump assembly completed. I'm still not sure about the foam/rubber sleeve but I'll pull it in a few weeks to see how it's holding up - it's ~1/4 submersed in gasoline. THe worst case scenario is it swells and turns to mush and I'll just fish it all out of the tank and strap the fuel pump straight to its support.
That was about as far as I made it Friday night. I didn't get home from work until 6 PM and we had company over so I really couldn't stay out in the garage all night.
I got up bright and early on Saturday and went out and attacked the stock fuel lines. They fell before me. There's really not a whole lot there. I'm going to try to reuse the stock brackets with a little modification to hold everything in place. Something about brake lines swinging around makes me nervous...
Here's what's replacing the stock hardware:
I ended up making a bracket to mount the FPR since I couldn't find a flat spot on the firewall. It's bare steel for now, but I will be painting it black for corrosion resistance.
The new fuel filter actually fit in the stock location using the stock bracket. It's a little smaller in diameter than the stock filter but I added some foam insulating tape to the stock bracket and everything is nice and snug.
You can see the lines in the picture above. Apparently I was a little too optimistic about the fittings and I'm going to need some 90 degree hose ends rather than the straight ends I purchased. I'll likely have a good amount of -6 AN hose and some straight hose ends left over so let me know if you're interested. So the fuel system project had to be put of hold for a few days but that's okay because I also had THIS to play with!
My custom aluminum intake manifold finally arrived! The port sizes are matched to my throttle bodies and engine. Some quick mock-up pictures on the new engine parts:
I noticed the throttle body sat really close to the front iron so I grabbed the alternator ot make sure everything fit:
Sure enough there's some interference with the TPS sensor and the air horn. Not really a huge setback but now I need to relocate the alternator. Fortunately this is common and several companies make relocation kits. I went with one from Aussy-land that puts the alternator where the P/S and A/C was. Hopefully it won't interfere with the steering column since it was designed for use on RHD cars. There's also going to be a tight fit between the TPS sensor and water temp sensor leads but that shouldn't be a big deal. I can always move the water temp sensor anyway...
One last mock up shot with the injectors for s****.
This is going to be a colorful engine bay: blue anodized air horns, purple anodized injector hats, red anodized FPR and fuel filter, black anodized hose ends and fittings and stainless steel line.
Oddly enough the manifold doesn't fit on my old engine that I'm using as a dummy. I'm not sure if the bolt pattern is slightly different or if some of the studs are bent. I'll mess with the studs so it'll fit on the dummy so I can continue laying everything out on the car.
Immediate to-do list (in no particular order):
-Install intake onto dummy enigne and wire injectors and TPS.
-Finish fuel lines.
-Build airbox and install/wire IAT sensor.
-Relocate/wire alternator.
-De-power steering rack.
-Wire starter
-Paint engine parts
Parts needed:
-Exhaust
-Rebuild kit (seals, gaskets, bearings, etc.)
-Clutch/flywheel
-Bunch of misc. engine parts
