have a question about turbocharging my pro 5
Luigi316
mazda protege 5 2002
hey guy i need some help am about to my protege 5 turbo with the stock engine can you guy help me with the set up what turbo sould i us and all that stuff thank for your help.
http://www.mazdas247.com/forum/search.php
http://www.mazdas247.com/forum/show...ng-your-P5-Here-s-a-guide-for-getting-started
if this is your first time turbocharging a vehicle, I highly recommend you do some research outside of this forum on the basics of how everything functions.
Things to consider:
-A stock FSDE is not a boost happy engine, boost higher than 10psi will almost guarantee a thrown rod. (even at 10 psi without a good tune is questionable)
-The Mazdaspeed Protege turbo components bolt right on
-make sure to get an SSAFC(or some type of EMS/Piggyback), Wideband, and boostguage with whatever turbo setup you decide to install.
Thank for the info this is my 2 time doing this I just want 8 psi am going to use a mazdaspeed protege Ecu those this Ecu help for that kind of boost.
Read the sticky at the top of this section and all the other ones. Any question you have will be answered just search for your self and spend a few days reading. Yes, days.
What I've always wanted are instructions or a FSM about how to actually install everything. I've never seen that anywhere on these boards. Turbocharging is something I want to do too sometime but have no clue how.
Again read the sticky top of this page if you can't do it based off those instructions you don't need to do it your self
You can look up the torque specs of the msp only thing you will be bolting up is manifold turbo an down pipe
