Mp5t
Status
Not open for further replies.
Sounds good. The 600 pounds you've shed is huge. Looking forward to seeing the power curve and to see just how much area is under it.
EDIT: With an estimate of 500 bhp, you're not far away from a Veyron in terms of lbs/hp. MP5T - 4.4 lbs/bhp, Veyron - 4.22 lbs/bhp
I hope it looks like a Supra Dyno starting at 3800 RPM... LOLz
I will never try for 500 WHP, I believe that would kill everything at once.
A Veyron also can put all of it down all the time... I am limited by FWD..
I believe that I might even be able to break traction at 90 MPH.
I do know that no matter what, whoever decided to take on the car, will underestimate it at least once...
Ten Random Shots...
The car is being run and driven this weekend..
Everything should work fine..
You and JT should be running this weekend!!!
P.S. glad to know i'm not the only one who loves monster that much
ahhhh sweet. hope everything works out and comes out smoothly for you
Cant wait see it back on the road! Plan on doing a dyno to see new #?
I had no dyno since 2006 and that was at 7 psi. I made mods every summer and never bothered to Re-Dyno. It was pretty evident that the car was becoming faster and able to waste "More Expensive" cars...
As of last year I became aware that 98% of the cars on the road can be out performed... There is nothing more satisfying than pulling away from a "Fast Car"
This year I need to Dyno so I will obviously post the results.
My goal is a stable 400 WHP as a minimum, then I will see how the tuning goes.
Status
