8
82735
^My 2cents. Get your fenders rolled. You're 215/45/17 1.8" drop I'm 225/45/17 stock so I'm wider than you, but you're lower than me so its a little different. Chalk either the tires or the fender (dry erase marker) to check out where it's hitting. I rubbed in the rear only grabbing the top edge of my sidewall and rolling them did the trick. Now I can hug corners like my summer set up was meant for. Just make sure to use a heat gun...otherwise your paint will crack.
Oh and I gave my car a much needed bath today!
