Team Pro5 Roll Call
dang good discussion going on here. lol since I dont feel i have cleaned up my car enough yet thats why my sticker is still sitting in my room waiting lol
2002 Protege5, manual 5-speed, Midnight Blue Metallic.
Interior:
Mazdaspeed Protege Gauge Cluster
Mazdaspeed Protege Door Sills
Mazdaspeed Protege seats with original P5 side airbags
DG Motorsports CF Glovebox Cover
Dave B brushed gauge rings
CR3 Dead Pedal
Alpine CDA-9883 Head unit w/ remote
30G Ipod Video (acts as stereo hard drive)
B&M short shifter
Custom Crown Royal Black shift boot
2010 Mustang Shelby GT500 Stock Shift Knob
White LED Map lights, Dome light, and trunk light
Defrost Mod
Exterior:
Xcelerated concepts ZX2 Carbon Fiber hood (Refinished with blue metaflake and pearl clear)
Aerocatch Plus Locking Hood pins with PasswordJDM Flush Mounts
Mazdaspeed front Bumper
AAC Bumper Sag Brackets
03.5 MSP lip
Morimoto H1 mini Bi-xenon projectors with Mini Gatling Shrouds
4300k bulbs with DDM 35W ballasts
Tail lights tinted and cleared
Full Custom exhaust
2.5” pipe
Cat delete
Resonator delete
Flomaster 2-chamber Muffler
3A Racing Exhaust Tip
Sickspeed Carbon Fiber Antenna (Black)
Sickspeed horns (Red)
LED License Plate Lights (White)
LED Projector reverse light bulbs
Suspension and Handling:
2008.5 MS3 wheels 18x7 +52 (Vintage Gold)
Bridgestone Potenza 225/40/18
Camber bolts (-1 on all four wheels)
Megan Racing Springs
Monroe Struts
Mazdaspeed Protege brakes (calipers, rotors, lines)
Mazdaspeed Protege Axles
AWR adjustable rear endlinks
Racing Beat rear swaybar
Engine:
VTCS deleted Intake manifold (Ceramic Coated Black)
Calloway Header
Mazdaspeed exhaust manifold cover
GT2554R Ball bearing Turbo
Calloway Down Pipe
HKS SSKV BOV
CR3 Radiator Brackets
CR3 ADP with Latch delete
CX Racing FMIC (Powder Coated Black)
Custom piping (Ceramic Coated Black)
10” Slim fans
Vac Block
As a minimum, this thread needs to be cleaned up. (1st because this is supposed to be a roll call of Pro5 Cars... If your car gets deleted from the thread, then consider yourself Kicked Out)
A Discussion thread needs to be created. (2nd)
People with Rust Bucket Pro5 or Bone Stock Pro5 or Non Pro5 need to get removed (Until they make an effort, and by that I mean, have a plan for becoming 1337 P5 Owners. Then they should apply, I'm not saying like some crazy initiation process, but a general... yeah that has what it takes to be here..)
Sorry to sound like an asshole here, but I don't ever sugar coat s***... so why start now...
So we will have a Team Pro5 "ELITE" in its own and will the Ultimate one be part of the Team?
Ya I love being part of team pro 5 I added a lot to my car just havented up dated I will wait tell u get my flared don and I will up date
Well Better Late Then Never
My name is Thomas. I purchased my car back in late 2004. Purchased it with about 70k miles, blown struts, eibach coilovers, 19" RHC5's, and a pretty disappointed previous owner. I've been a part of TeamPro5 since 2007 when Effren found me trolling the forums. When I first joined TeamPro5 my car didn't have much done to it. Just the basic IHE, eibach coilovers, and a sound system. I've blown a hole in my first motor due to oil starvation, which led to rod knock, which led to BOOM. I'm in the process of rebuilding my second motor due to a broken HVAC hose which turned into a serious overheat, which caused the head gasket to give. Now my car is just sitting in the garage collecting dust while the motor is at the machine shop. I'm waiting to get it back so a friend and I can start assembling it. When I do get it back a lot if not most of my "Waiting To Be Installed" list and "Waiting For Delivery" list will be going in. I also plan to rattle can black my engine bay to cover up the yellow. My car has transformed several times and keeps on doing so till this day. There's a lot more history to my car but we can save that for some other time.
Other interests I follow are building computers, computer water cooling, and basic networking.
Here are some pics...
Engine Mods:
-Garret GT3076RS Turbo Ceramic Coated
-Tial 38mm Wastegate
-Custom Intercooler w/pipes
-SPOOL Ceramic Coated Turbo Manifold
-Custom Downpipe
-TurboXS Type-H RFL Blow Off Valve
-Shane Racing Light Weight Crank Pully
-JDM Mazdaspeed Intake Cam Shaft
-JDM Mazdaspeed Exhaust Cam Shaft
-Indigo Light Weight Alternator Pully
-Indigo Light Weight Water Pump Pully
-AWR Front Motor Mount
-SLS Passenger Side Motor Mount
-AWR Rear Motor Mount
-Street Unit Driver Side Motor Mount
-626 Intake Manifold
-Injen Hydroshield
-Custom Polished Aluminum Radiator Brackets
-NRG Carbon Fiber Hood Dampners
-Magnacore Spark Plug Wires
-EGR Block Off Plate
-Weapon-R Engine Damper
Fuel Management Mods:
-Split Second Air Fuel Controller
-Perrin Fuel Rail
-Mazdaspeed ECU
-J&S Safeguard
Transmission/Drivetrain/Shifter Mods:
-Fidanza 7.5lb Light Weight Flywheel
-Act StageI Heavy Duty Clutch Plate
-Exedy Street Disc
-GoodRidge SS Clutch Line
-TWM Short Shifter
-TWM Shift Link Bushings
-Corksport Bronzeoil Bushings
Exhaust Mods:
-Tanabe Muffler
-Custom 2.50" Mandrel Bent Piping (Catless)
Cooling Mods:
-Samco Radiator Hoses
-Mazdaspeed 1.3bar Radiator Cap
-Spal Fan
Brake Mods:
-Goodridge SS Brake Lines
-Front Wilwood Big Brake Kit CDS 13" Rotors
-Rear Brembo Cross Drilled Rotors
Suspension/Handling Mods:
-BC Racing Coilovers (BR Series)
-Progress 22mm Rear Sway Bar w/Custom Brackets
-GT-Spec Front Tie Bar Brace
-GT-Spec 4pt Ladder Brace
-GT-Spec Rear Strut Tower Bar
-GT-Spec 4pt Linkage Bars
-GT-Spec Trunk Reinforcment Bar
-GT-Spec Lateral Arms
-GT-Spec Front Strut Tower Bar
-GT-Spec Rear Link Panel
-GT-Spec V-Brace
-Universal Floor B-Brace Bar
-Sparco Harness Bar
Tires/Rim Mods:
-19" Racing Hart C5's (custom painted)
-F 215/35/ZR19 Kumho Ectsa SPT
-R 215/35/ZR19 Kumho Ectsa SPT
-Spare Mazda3 Hatch Rims w/BFGoodrich Grid019 205/45/17
-H&R 20mm Spacers(only used when running the Mazda3 Rims)
-Buddy Club JDM Forged Extended Lug Nuts
Appearance Mods:
Exterior::
-iSport Carbon Fiber MSP Lip
-JDP Carbon Fiber Lip
-DGM Carbon Fiber Grill
-DGM Carbon Fiber Mirror Covers
-DGM Carbon Fiber Oil Cap Cover
-Seibon OEM Style Carbon Fiber Hood
-XC Carbon Fiber Wing(sticker bombed)
-Mazdaspeed Fog Light Delete Covers
-JDM Front License Plate Bracket
-Custom Headlights TSX Projectors
-Tenon HID Kit
-Front V-LEDS Type 2 Dual Color Changing White/Amber 60 M-SMT Turn Signal Lights
-Reverse V-LEDS HID White 14 M-SMT 5W High Power Lights
-Black Altezza Tail Lights
-MintBlue Rear Bumper
-MintBlue Side Skirts
-EBay Carbon Fiber Fuel Door
-Ebay Carbon Fiber Door Trim
-Wings West Hood Bonnets
-PIAA Super Spoza w/Spoiler Windshield Wipers
-Mazda6 Rear Wiper
-Celica Clear Corner Side Markers
-Visual Garage Shark Fin Antenna
-iSport Carbon Fiber WeatherTech Window Visors Cloned
Interior::
-Custom Glovebox Cover With 5.6" Screen
-DG Carbon Fiber Radio Cover
-DG Carbon Fiber Passenger A-Pillar Cover
-Mazdaspeed Leather Shift Boot
-TWM Magnum.44 Shift Knob
-Carbon Fiber Trimmed Ash Tray
-Lots Of 3M Carbon Fiber Di-Noc
Audio/Video:
-Clarion 675VDII Double DIN
-Clarion iPod Control
-Clarion 940N DTS PrologicII Processor
-Clarion OHM102 Flipdown Screen
-Clarion TTX7501z TV Tuner
-Diamond Audio 4" Center Channel Speaker
-Infinity 6.5 Component Speakers
-MMats 6x9 Pros Spearkers
-12" Rockford Fosgate Sub
-Savv 5" Rear View Mirror Monitor
-Kicker DX700 Amplifier
-Rockford Fosgate P400-4
-1 Farad Cap
-2 Farad Cap
-Monster Cable Interlink MKII RCA's
-Monster Cable Monster Video3 Video Cable
-Monster Cable Ultra Series THX 1000 Subwoofer Interconnect RCA
-Monster Cable Ultra Series THX 1000 Speaker Cables (sub only)
-Monster Cable Playstation 2 Interconnect Cable
-Sony Playstaion 2
Gauges/Monitoring:
-AEM UEGO Wideband
-AEM Voltage
-AEM Tru-Boost Controller
-Prosport Premium Oil Pressure Gauge
-Prosport Premium Fuel Pressure Gauge
-PLX OBDII-100 Scan Gauge
-Turbo Timer
-Mazdaspeed Canadian Gauge Cluster
-TurboXS Knocklite
-ForceFed Single Gauge Steering Column Pod
-Custom Dual Pod Gauge Cluster
-Autometer 3pod Gauge A-Pillar
Misc:
-Removed Side Moldings
-Hella Supertone Horns
-Viper 2-Way Alarm
-Vibrant Vacuum Distrubution Block
-Hose Techniques Silcone Hoses
-Custom Paint Graphite Grey Pearl
-AAC Bumper Brackets
Recognition:
Official July 2008 Mazda Of The Month
Official December 2009 Mazda Of The Month
Waiting To Be Installed:
-Medievil Light Weight Power Sterring Pulley
-Microtech LT8s ver.1
-550cc Mopar Fuel Injectors
-NSN Throttle Body Spacer
-NSN Intake Manifold Spacer
-Arias 8.5:1 .020 Overbore Forged Pistons
-Pauter Forged Rods
-ACL Main Bearings
-ACL Thrust Washers
-ACL Rod Bearings
-ARP Main Studs
-ARP Exhaust Studs
-ARP Head Studs
-Cometic Engine Gasket Set
-Cometic Head Gasket
-Transmission Cooler
-Oil Relocation With Oil Cooler
-Upgraded Front Rotors
-WeaponR Oil Catch Tank
-WeaponR Coolant Overflow Tank
-Pedders Urethane Control Arm Bushings
-Urethane Front Swaybar Bushings
-Mishimoto Radiator
-2x 12" Spal Pull Fans
Waiting For Delivery:
-Custom Radio Bezel With Triple Gauge Pod
-Custom Shift Plate With Hazard Switch
-Misc. Russel/Earl Fittings For Oil/Trans Cooler
-Prosport Evo Water Temp Gauge
-Prosport Evo Oil Temp Gauge x2 (one will be used to monitor trans oil temp)
First of all, those wheels....(butthump)
Secondly, Yay...more nerds. I have Degrees in both Electronic Engineering Technology, and Computer Engineering Technology.
Bump
Edited first post to include a list of members that have posted in this thread w/Links to their post. This should help if you ever find the need to admire your ride or update pictures, mod list, etc.
Also lots of posts don't sport the "TeamPro5" sticker in their Pictures :(
P.S Brian_MP5T what happen to your Roll Call Post?
dan fletcher
INeedMoarLow
white 2002 pro5
<a href="http://www.flickr.com/photos/69766646@N07/6817428498/" title="skate32 by INeedMoarLow, on Flickr"><img src="http://farm8.staticflickr.com/7070/6817428498_959f3a79ef_z.jpg" width="640" height="194" alt="skate32"></a>
<a href="http://www.flickr.com/photos/69766646@N07/6963551277/" title="skate31 by INeedMoarLow, on Flickr"><img src="http://farm8.staticflickr.com/7068/6963551277_483f00a138_z.jpg" width="640" height="398" alt="skate31"></a>
<a href="http://www.flickr.com/photos/69766646@N07/6963542299/" title="skate6 by INeedMoarLow, on Flickr"><img src="http://farm8.staticflickr.com/7205/6963542299_537210a32a_z.jpg" width="640" height="427" alt="skate6"></a>
<a href="http://www.flickr.com/photos/69766646@N07/6817422208/" title="skate14 by INeedMoarLow, on Flickr"><img src="http://farm8.staticflickr.com/7054/6817422208_c0fa7b14bb_z.jpg" width="226" height="640" alt="skate14"></a>
suspension:
BC Racing BR coilover
-3* fronts
-5* rears
wheels and rubber:
xxr 002's red polished lip 16x8 +0
205/40/16 falken 512's
Engine:
MP3 ECU (flashed)
Injen intake with K&N filter or RE metal filter
PnP msp intake manifold with VTCS removed
Intake manifold spacer
midevil lightwieght pulleys alt,ps,wtp
RR-racing UDP
2.5 inch mandrel bent j-pipe back exahust with a vibrant tpv muffler, vibrant resonator, and magnaflow resonator
MSP oil cooler setup
MSP shifter
kartboy shifter bushings
Corksport bronzoil bushings
Corksport exhaust hangers
SU rear MM
midevil front mm
Awr side inserts
ground kit
Appearance:
DGM fiberglass grill
DGM fiberglass rear valence
MSP black hood (sometimes)
MSP engine cover
MSP shift boot and knob
Midevil ADP
tuner lugs
original dave-b rings
familia and 323-f badges and evil M
Black p5 wing
Black mirrors
blacked out headlights and side markers
shorty antenna
tinted tails
yellow lamenx film for foglights
tint
decals
Safety:
Prosport oil pressure gauge
Forcefed steering column pod
MSP alarm
Techone HID kit 3000k
future mods:
custom paintwork
vent visors
wink mirror??(too played out?)
led license plate lights
led interior lights
dan fletcher
ineedmoarlow
white 2002 pro5
<a href="http://www.flickr.com/photos/69766646@n07/6817428498/" title="skate32 by ineedmoarlow, on flickr"><img src="http://farm8.staticflickr.com/7070/6817428498_959f3a79ef_z.jpg" width="640" height="194" alt="skate32"></a>
<a href="http://www.flickr.com/photos/69766646@n07/6963551277/" title="skate31 by ineedmoarlow, on flickr"><img src="http://farm8.staticflickr.com/7068/6963551277_483f00a138_z.jpg" width="640" height="398" alt="skate31"></a>
<a href="http://www.flickr.com/photos/69766646@n07/6963542299/" title="skate6 by ineedmoarlow, on flickr"><img src="http://farm8.staticflickr.com/7205/6963542299_537210a32a_z.jpg" width="640" height="427" alt="skate6"></a>
<a href="http://www.flickr.com/photos/69766646@n07/6817422208/" title="skate14 by ineedmoarlow, on flickr"><img src="http://farm8.staticflickr.com/7054/6817422208_c0fa7b14bb_z.jpg" width="226" height="640" alt="skate14"></a>
suspension:
Bc racing br coilover
-3* fronts
-5* rears
wheels and rubber:
Xxr 002's red polished lip 16x8 +0
engine:
Mp3 ecu (flashed)
injen intake with k&n filter or re metal filter
pnp msp intake manifold with vtcs removed
intake manifold spacer
rr-racing udp
msp oil cooler setup
msp shifter
corksport bronzoil bushings
corksport exhaust hangers
su rear mm
midevil front mm
awr side inserts
ground kit
appearance:
Dgm fiberglass grill
dgm fiberglass rear valence
msp black hood (sometimes)
msp engine cover
msp shift boot and knob
midevil adp
tuner lugs
familia and 323-f badges and evil m
black p5 wing
black mirrors
shorty antenna
tinted tails
tint
decals
safety:
forcefed steering column pod
msp alarm
techone hid kit 3000k
future mods:
Custom paintwork
vent visors
led interior lights
love the stance! I want
-Naresh Seeparsad
-nareshseep
-Mica Blue
-Solodex aka autocross
Naresh: Suzy (Hatchback-RSS)
ENGINE
1.5 svt motor (rated at 130hp crank with 7500rpm redline)
Exedy Stage 1 clutch
Corksport radiator 3core with OBX Silicone Radiator hoses
Ingen short ram intake with K&N filter
Fugitsubo exhaust with decat on stock piping
Throttle body coolant bypass mod
Grounding kit
ZMDE (1.6)intake manifold
Redline 10W30 engine oil
Redline 75w90ns gearbox oil
SUSPENSION
Carbing front strut bar
Sport 20 front sway 22mm
Progress rear sway bar 22mm
KYB shocks
Mazdaspeed front springs (rear springs need new struts with the higher perch)
Upgraded rear endlinks(group buy), prothane greasable bushing and bracket
Enkei RP01 15x7 14 lbs rims
ICE
Headunit Premier 6900 UB, soon to upgraded to a Car PC
Front Stage: DLS RS6a components
Mids amp: USAMP Xterminator 1600.4 (to be installed)
Subwoofer:Elemental Designs 13ov sealed 1 cuft box (to be installed)
Subwoofer amp:Phoenix Gold 200.2
PROJECTED INSTALLS
Replacing LEDs on middle console and dash -done
air flow ratio gauge and vacuum gauge
Projector retrofits for headlight
DC to AC adaptor
Management : ??
Oil catch can
P1030010 by nareshseep, on Flickr
Untitled by nareshseep, on Flickr
P1020987 by nareshseep, on Flickr
obx by nareshseep, on Flickr
If it's nareshseep's car you are talking about, his car is not a swap. It's JDM, with the 1.5l ZL-VE with SVT. Same engine as mine just his is manual and that car runs like great and handling is like a dream...Just in case it was that car you were talking about ;)
