you dirty bastards. if anyone ever sees a kcco shirt on sale let me know. i gotta have one
Does anyone know in a breaker box, if you have two switches on one circuit for 220v, and they both have 50A ratings, is that a 100A circuit? Is older wiring rated for that kind of stuff? I mean 100A seems like a lot.
NO! The rating that is on the breaker ex. 50A is the rating if you have a single breaker its a 110v 50a breaker aka a 50 amp single pole breaker. if you have a breaker that is double the width and is rated @ 50 amps it is a 50 amp double (2) pole breaker which is rated @ 50 amps but 220v. the amperage rating doesn't go up but the voltage does. 220v breakers are used for large electric appliances (stove, dryer, hot water tank, A/C.) or in your case a 220v air compressor. And as far as wiring goes it is rated as well 14ga. wire is mostly for lighting and is rated upto 15a, 12 ga. wire is for recepticals and is usually rated upto 20a. 100 amp wire is usually 6-8 ga wire. hope that helps.
Thanks! I hate being a total newb about things concerning electricity!
Better start laying out a flat bottom for the rest of the car then...
I want to see how it turns out first on the rear bumper. I haven't decided if I want to do the rear in carbon fiber or fiberglass. If anything I can make a mock up out of fiberglass then go all out if it turns out sick. Then a flat bottom can follow. Soon to be "because race car"
yea but for autocross, 1 fun mod can put you in a class where you are not at all competitive...
I also see his point of just wanting to fabricate fun stuff too. Half the fun of this passion is working on the car. I want to make brake ducts eventually. Do I need them? Heck no. But it will be fun.![]()
