To get a third AUX key, you can order a chipped, key blank from Jason at Montgomery Mazda (onlinemazdaparts.com) for $24.94 plus shipping (
see here).
Jason 704-563-1510 ext141
OnlineMazdaParts.com
Montgomery Mazda Charlotte, NC
If you provide your VIN number when ordering, he'll cut the key for you. After you receive it, you will need to program the car to recognize the new key:
NOTE: This procedure requires the two chipped keys that came with the car. If you only have one key, the registration of a new key must be done at the dealer (I have also heard of locksmiths who can "clone" the RFID in the one good key to a new key, but that key would be sold by the locksmith).
First, identify the three metal programmable keys. Numbers 1 and 2 are the metal keys that come with the car. Number 3 is the new metal key to be registered.
Assure that the AKE fobs are away from the car during this procedure, so that they do not influence the starting system.
A. Launch Programming Mode
1. Turn the ignition switch to the ON position using key 1.
2. After verifying that the key-shaped security light illuminates for approximately 3 seconds and turns off, turn the ignition switch to the LOCK position within approximately 5 seconds using key 1.
3. Remove key 1.
4. Turn the ignition switch to the ON position using key 2.
5. After verifying that the security light illuminates for approximately 3 seconds and turns off, turn the ignition switch to the LOCK position within approximately 5 seconds using key 2.
6. Remove key 2.
B. Perform Additional Key Programming
1. Turn the ignition switch to the ON position using key 3.
2. Verify that the security light illuminates for approximately 3 seconds and then turns off.
3. Remove key 3.
C. Verify Key Programming Is Correct
1. Verify that the engine can start and run for approximately 5 seconds or more using all the registered keys. Wait 5 seconds or more before starting the engine using the next key.
IF SO, you're done.
IF NOT, repeat and try again, precisely following the procedure.
