Protege part out round 2: revenge of the zoom-zoom-boom
Pics are here https://picasaweb.google.com/111179442365291253508/ProtegeStuffForSale#
Prices are shipped in the continental U.S., will ship outside that for an additional cost. I'm willing to negotiate on prices if you are buying multiple things as it makes life easier for me!
Zeitronix ZT2 gauge system - $325 shipped Wideband AFR, exhaust gas temperature, and boost sensors included. It can datalog and be wired into your RPM, very cool! I paid over $600 for this system. I'll include my DIN mounting hardware as well (it goes right below your CD player)
Turbosmart manual boost controller - $40 shipped Crank up the boost and blow your motor like me!!! :)
Mazda owner's manual case - $15 shipped Owner's manual not included, but case is in excellent condition. Includes original sticker of car! :D
wheel spacers - price varies pair of Project KICS 10mm that can have studs pressed in, $50 .
MSP exhaust heat shield - $25 shipped Cut out for O2 sensor.
Mazda Protege workshop manual and transmission rebuild guide - $70 shipped
Two brand new brake dust shields - $15 shipped no clue why I have these
OEM floor mats - $30 shipped Three in excellent condition, driver's mat needs cleaning and is torn where it flexes (see pics)
Stock rear sway bar - SOLD!!!
Momo Monte Carlo steering wheel + accessories - SOLD!!! Includes hub for Proteges (probably fits other Mazdas as well), a spacer for the steering wheel, and the wheel. Wheel is worn but in good condition. Horn button found and included! :D
Enkei RPF1 16x7 wheels - SOLD!!! +43mm offset, Bridgestone RE-01R 205/55/16 tires on them. The wheels are in great condition, two wheels have very minor nicks which I tried to capture in the pictures. Two tires are decently worn, the other two are good tread depth. Very light wheel combo!
Apexi air filter- SOLD!!!
8mm spacers SOLD!!!. pair of 3mm spacers SOLD!!! for those.
MSP axles (pass + drivers) -SOLD!!! A little bigger diameter than standard Protege axles! *I broke two axles thanks to autocrossing with r-compound tires.
Dexter's hood prop kit! - SOLD!!! One of my first mods... and maybe the best. I sent him a PM about these 7 years ago to the day. Wow!
Protege 5 roof rack delete strips - SOLD!!! I have two unused adhesive clips, you'd need to buy 6 more I believe (~$2 a piece).
AWR motor mounts - SOLD!!! Front and rear motor mounts, side insert (stretched, slightly torn from getting on and off the mount, but still works good) and transmission insert. They are aged looking but still function great.
Protege 5 rear cargo cover - SOLD!!!
AWR deep sump oil pan - SOLD!!! Tapped for turbo oil return, higher price includes drain line (super nice fit, I'm proud of those hours I spent trying again and again). Includes spacer for the pickup and hardware (hardware needs de-gunked or replaced, I'll leave it to the buyer to do that themselves).
GHL 3" down-pipe and exhaust - SOLD!!! Probably the nicest piece I bought for my Protege. This has been shortened to fit the P5. Tapped for EGT sensor. Full disclosure: When my motor blew, it made a hole in the downpipe. I had it welded shut and should be good now. See the pictures.
ARP extended studs - SOLD!!! Set of 10.
McMaster Carr vacuum block - SOLD!!!
Blacked out headlights - SOLD!!! Broke the damn mounting tab on the driver's side headlight... (boom06)
MSP springs - SOLD!!! They are red! :)
Walboro fuel pump - SOLD!!!
Corksport rear strut bar - SOLD!!!
Boostsciences reflex diverter valve - SOLD!!!
AWR 21.5mm rear sway and endlinks - SOLD!!! There is a bolt sheared in the mounting bracket. Worst case scenario you buy a new bracket for $25 from AWR. Mounting hardware not included. Thus the low price.
New axle nut and oil seal - SOLD!!! Or free if you buy something else
Sparco 4pt harness - SOLD!!!
Stainless steel clutch line - SOLD!!! A must for anyone with an aftermarket clutch
MSP exhaust manifold - SOLD!!! No cracks, good condition!
Need anything off of the motor (70k miles)? Let me know, I can pull it. There are holes in both sides of the block though...
Power steering pump - SOLD!!!
Alternator - SOLD!!!
Starter - SOLD!!!
Fuel rail - SOLD!!!
EGR valve - SOLD!!!
Coil packs - SOLD!!!
Water pump - SOLD!!!
O2 sensors - SOLD!!!
Valve cover - SOLD!!!
Throttle body w/ sensor - SOLD!!!
Oil pump -SOLD!!!
There are still good items in my other thread, check it out http://www.mazdas247.com/forum/showthread.php?123805473-Protege-part-out-round-1 Wideband AFR/boost/EGT system available, wheels, and more.
Thanks for looking!
I'll take those roof delete strips. PM sent. And that's a great deal on MSP axles. I spent $250 for mine used...
And you still have the RPF1's for sale? Come on, people! Those are awesome wheels!
Got your PM, thanks! I love those wheels and can't believe I haven't been able to get rid of them yet. I wish they were 17x9s so I could put them on my new car!
Darn....what junkyard? Sounds like a good enough reason for a road trip. :)
It went to Wrench N Go here in Des Moines Iowa. It has been a couple months though, it has probably moved to another home. :(
Oh don't you worry about those wheels. I'm going to snatch them up as soon as I can afford them.
You should really try purina one or something... seatbelts are terrible for dogs! :D
hahaha good one! but really, no seat belts for the back seat????? i bought some from someone here but he sent the wrong ones! now i lost my money and got stuck with seatbelts i don't need!
They went to the junkyard unfortunately.
All parts should be shipped out today... sorry for the wait! - Lil Wayne
Got my roof rack filler strips. Once again, a great seller. Thanks again, mate! (2thumbs)
Thanks for the kind words Evan.
bump. Someone buy these wheels and the Zeitronix! :D I need money so I can have excuses to buy new parts for my S2000... otherwise I can't justify it :)
