Protege Headlight Conversion installed on a P5! I need turn signal wires!!!
M2P503
2003 Mazda Protege5
Hey Guys i have a 2003 Mazda Protege 5 and i just removed my stock Protege 5 headlights and i installed Protege Headlights instead. My Low beams work but my High beams don't and my inside turn signals by the grille work but they signal very fast Why do they signal really fast? Also i don't have the wiring harness for the Outside turn signals by the fender on the head light . I need the wiring harness for the turn signal lights by the outside by the fender. Does any one know if there is a wiring conversion kit for these? Please help!
I believe there is a harness for you to connect your high beams and low beams to the headlight so you can use a dual beam bulb. As far as a harness for another turn signal...Dunno...You could just splice a connection into the existing parking lights
Ok who sells the harness how much is it?
P5 has a dual beam set up and works way better sedan has single beam and mine at least sucks go back to the p5 lights unless you want to splice some wires. Signal lights clicking fast is usually a bulb out
Hello Tweety thanks for letting me know. Although i found out that it's not a blown bulb but it is the Fillament that is different inside the bulb that makes the difference. The Protege signal lights are different than the Protege 5 signal lights it's the Fillament inside them that makes thme different . It's hard to explain
check ebay, you just need a 9005 pigtail adapter, or whatever number it is. fairly cheap too.
is that why the fast blinking is occuring?
Ok thanks man ill check E-bay for the PigTail Adapter and yes that is why there Blinking fast. because of the Fillament inside the bulb is different
I checked E-bay for the Pigtail adapter and they don't list any for our car. that 9005 one is just for a Volkswagen/sti. Where can i get a Pigtail adapter for an P5?
