Just purchased my JoeP FCD. Fuel-cut is killing me.
Cause the superstock map is made for stock boost. Duh lol you need to dl a 10psi tune
Um.. Okay on the FAQ it shows that it's capable of handling 10psi, but not to exceed that. I know I've been hitting higher boost levels, but I've watched it happen at 10psi... So... And I know I've got a front mount and it's been low temperatures recently, so there are other factors at play here.
colder temps will do it, but instead of searching through 150+ pages for a map...just tune off of the superstock map. Either way you go, whether looking for another map or not, you will be adjusting the tune for your specific setup.
I understand that, but I'd like to start with something closer to what I'm at.
Cleans up nicely once you paint the IC piping!
Some satin black paint from walmart. It chips off fairly easy but i should of did a better job at scuffing it then what I did..
Edit: Yes, I'm fully aware of my strut bar looking like complete ass!
I really wanted to tell you that you should have painted that strut bar...
I didn't even notice the strut bar, but yeah it could use a little TLC...overall, Im loving the pipes though. and Preferio, let us know how that map works later on.
yeah this is the bolt (just used stealth's to show real quick)
it's actually sticking up a little bit, so i may be able to get a grip of it with some pliers, but i may just end up buying the screw extractor thing i saw it at home depot for > $5
