hornsfan10609
Certified Mazda Tech
- 2003.5 Mazdaspeed Protege x2
Timing being right is important but you would know if it was off. It is normal for the pistons to be dirty.
Did you do the wrench and vise grips trick on the cams to keep them from moving while you installed the belt? Post a pic of the cam gears already! I always set the timing without the Crank pulley installed and use the notch on the crank. 220whp may be a little high of an estimate but it should be somewhat close to that.
not necessarily, we can't see the belt or if the tensioner is actually engaged.no bueno chico
Screw the timing cover and crank pulley. Align the intake and exhaust cam gears. Align the crank timing SPROCKET with the casting mark on the block. Start putting the belt on the exhaust cam gear first, then route it thru the tensioner idler then round the crank sprocket then around the tensioned then around the intake cam gear. There is not supposed to be any slack on the idler side of the belt.
Try moving the injector to a different cylinder and see if the pooling oil/gas is now in a different cylinder. Otherwise its leaky valve seals.
b6gtxawd said:hey man just wondering if you could tell me how to tighten my timing belt. i just re adjusted my timing belt to where it should be after the guy i paid to do it ****** it up. sooo i replaced my stretched out tensioner spring and put all my parks to where they should be, then rotated my crank pulley 4 times to make make sure the marks still lined up. they were slightly off (cam gear marks) which i then relized it was because there was a tiny bit of slack in the belt so when i tighten the belt it does line up very nicely. sooo how would i get the belt nice and tight now that everything is on?? the tensioner is on but the bolt still needs to be tightened. pls help
