03.5 Blazin yellow MSP partout
Status
Not open for further replies.
I saw the grille was gone but how about the lower driver fog light cover? mine has no fog lights but has the grilles instead.
Thanks.
Gary
Hey I see your in Indiana, is there a way I can come over sometime and pick up the gas cap door? Or we could just ship which ever is easiest
^Be way easier to ship it but if you wanted to pick up an extra hood that perfectly matches to have a back up or check out some other parts I've got for back ups let me know.
pat this is the same guy i bought my old parts off good guy not a far drive he met me at wal mart or something
Ya good seller, I bought the gas door last night and its already on its way, bump for a great seller
Edit: extremely good seller just got it, thanks
^lol! Wish I had 50 shift knobs. That was the very 1st part I sold in the partout back in April 2010. Check redline if you want the badest shifter boot you can get!
instead of posting what you sold, why not post what you have left??
would give us(and me) a better opportunity to buy something off you :)
^you ever parted out an entire car before? There's a s*** load of nickle and dime parts that would take WAY to much time to list. Listing parts sold is the easiest way to list parts and has worked just fine for a year and a half. And I've tried to post that list on every page. The best way to find out if I have something if your to damn lazy to look at the parts sold list is ask me what you need!
Still got some parts left guys!
Updated list of parts that have been SOLD:
Side markers, shift knob, washer kit, lower grill, door sills, headlight supports, ecu cover, DF inner wheel plastic cover, egr tube, cup holder(shifter bezel), inside DR door handle, shift boot, Ebrake boot, TURBO KIT(rad+intercooler, rad brackets, turbo, wga, oil+coolent lines+ oil cooler, exhaust mani+shield, S+J pipe, hot+cold pipes, air box, MAF, BPV+hose, MSP ecu, ac condensor), PR door complete, rear strut hats, front A pillars, Engine, headlights, RB springs, climate controls, insturment cluster, wheel center caps, coolant reservior, engine harness, glove box cover, fog deletes, msp engine cover, R skirt, hood latch, msp pedals, dual cat, both O2 sensors, dash bezel, rear cross member, bumper cover, pass axle assm, bump stops, spare tire and cover, dipstick, DS jam sill, coilpacks+plug wires, DS rear caliper, DS front caliper, TRANNY, DS door, DS fender, 03.5 LIP, PS rear view mirror, radio bezel, grill, pr seat belt assm, horn, sub brackets, Pass ABS sensor, Driver's side hub and axle, pass window switch bezel, brake booster line, sub encloser kit, fuel pump, fuel pump assembly, dimmer switch, seat covers set, radio pocket, ac compressor, rear MM, shifter, shifter plate, shifter link arms, master cylinder, clutch master cylinder, slave cylinder, clutch line, throttle cable, gas-brake-clutch pedals, pressure plate-clutch disc, flywheel, starter, 03.5 spoiler, gas door, trunk mat
Status
