GI Adjustable Rear Endlinks
Status
Not open for further replies.
1.Wildcard26*
2.Protege3690
3.nareshseep*
4.repthemazdas
5.halfbreed*
6.SCMP3
7.datboibrian18
8. shootz
9.slipkornvayne
10. speedpx
11. Gjmoreo
12.puertorico
13. b_dues
14. destineal
15.
sorry if i missed this, these are for the stock rear sway? if so, i'm in...thanks
I think that they should be able to work for your stock rear sway but when you decide to put in the Racing Beat or Progress you will require adjustable linkages. You won't be able to use the stock linkages on these sways as they can bend or snap them.
^ good ? because i plan to upgrade my sway bar
i dont believe thats correct! just saying,
These endlinks can be used with oem or aftermarket sway bars, but when you upgrade your sway bars and struts you want to upgrade your endlinks because the oem ones arent designed to handle the stress from an upgraded parts so you would indeed need to upgrad the endlinks. The oem ones will bend and or snap after some time which is why its recommended to upgraded your endlinks, adjustable ones are the preferred choice.
I have the front and rears from the last GB and i only installed my RB FSB the rear is still the oem one. I had to use the adjustable ones due to the location of the tab on the struts it was higher which called for longer endlinks i figure since im gonna buy some why not get adjustable ones.
well i dont think thats correct on this^^^ i think you meant to put adjustsble endlinks, thats what got me off.
he got it right hes saying that the stock links will bend or snap if you upgrade the sway bar. I dont see what you missunderstood but it dont matter anyways the point got across so back on topic.
so to answer your question bazooka yes you can use them with stock or aftermarket swaybars.
Status
