Steedspeed with ext wastegate
Sorry it took so long but this is the pics of my turbo set-up
Steed Speed manifold with ext waste gate and 02 sensor
Gt 2876
cork sport down pipe
cork sport radiator
perrin FMIC
thanks. The flanges came in today. Off to the shop to discuss how to do install
yes it def. does and now my down pipe just broke ugh and someone hit my front bumper what a week ugh
I am trying to find a V band clamp system that allows the wastegate to be attached to the manifold. This will allow the wastegate to be rotated for simple dump tube back into the down pipe. It has the 2 standard flanges (38mm) with a v-band adapter in the middle. If anyone has a link please post. I have tried ebay.
Are you talking about the vband 38mm ewg?
Yes. I saw on ebay sometime back there was a kit that had the standard diamond shape flanges(qty2) and a V band adapter between. Which means you can bolt the WG to it and the kit to the flange on the manifold, then rotate the WG into what ever position you want.
Yes. The flanges(qty2) are 38mm with V band clamp. The shop that is doing my set up has 1 but it come with a new WG.
Ok. Manifold is on, water and oil lines connected. Hit a snag. Have to do some changes to the inter-cooler piping and the DP. Hope to be done tomorrow.
