Is there a ECU chip for the Mazda 2 to add more horsepower as you could for an example a VW GTi.
What's a ref lash?
Should be "reflash." Reflashing your ECU is essentially like loading a different operating system onto a cell phone or computer. You plug in through the OBDII comms port on the left side of the dash and basically install a new computer program onto your ECU so that it mixes air and fuel differently as well as changes where the rev limiter is (and on an Auto Trans it probably can alter shift points).
Recommended?
Im thinking about sending my ecu to DP Tuning next month. Would be pretty sweet if they posted a Dyno Sheet for the Mazda 2 with the A/F results. The gains they speak of are almost too good to be true. Most reflashes you can expect 5hp even 10 is pushing it... Maybe our engines are really undertuned from the factory. Also mpg results would be nice too
When I called dptune they said stock mazda 2 makes 68 whp flashed it 100whp . Almost unbelievable
