FS: NEW GT2554 turbo, Apex 2.5" DP, s-pipe,oil line kit,fuel rail, mounts, brake pads
Howdy folks, I'm selling the stuff listed below. Shipping is limited to the lower 48 states and Canada.
***RESONABLE OFFERS WILL BE CONSIDERED***
BRAND NEW Garrett GT2554R turbo. This is a brand new unit, with no miles on it. This is stock replacement and requires no engine management on top of the MSP ECU to run properly on an MSP. Mounts to the stock MSP exhaust manifold or any similar, compatible manifold and the stock s-pipe bolts up without issue. INCLUDES: 6psi wastegate actuator and wastegate bracket, both installed. Beautiful piece of work and does not need to be clocked for stock MSP installation. Specs can be found here. SOLD
USED Apex 2.5" catted one-piece J & Mid-pipe. Despite some mild surface rust (easily removed for some high-temp painting), this thing is beautiful. It was one of my favorite modifications. I only removed it because I thought it was leaking, but my actual problem turned out to be a cracked Corksport s-pipe. Works flawlessly. This product is no longer manufactured and is an extremely rare, difficult piece to find. Includes O2 sensor & stock rear O2 sensor harness. SOLD
NEW oil line kit. This is a kit for installing or replacing oil lines to the turbo. Includes new stainless steel braided lines and all connectors, fittings, restrictors, flanges and gaskets. Perfect for anyone replacing old oil lines or installing a turbo on a non-turbo Protege. Price: $60 shippedobo
USED Stock fuel rail. I thought something was wrong with my stocker, turned out to be a bad fuel pump clip. This includes the FPR and the bulby thing at the end (forgot what that is) but no injectors. SOLD
USED AWR rear motor mount. 70 durometer. I actually really liked this, but my elderly mom was complaining about the stiffness (which didn't bother me). Mint condition, only used for about 250-300 miles. SOLD
USED stock front motor mount with Corksport inserts. Again, I liked the inserts but my elderly mom complained, so I had to get something softer. Anyway, I think the stock bushing has a small tear/crack in it, nothing major. The inserts eliminated any effect the tear/crack may have had.
Price: $40 shipped obo.
NEW PosiQuiet ceramic front brake pads. SOLD
USED stock s-pipe. This pipe comes off the turbo and connects to the j-pipe. Perfect for a mild porting job prior to installation. No cracks or flaws. SOLD
Additional pics:
Would you consider shipping turbo to Canada? I am dire need! I have bought and sold thousands of dollars worth here on the forums.
I sent you a PM as well, but haven't heard back. We can work out a deal if you're still interested. Let me know...
im interested in the oil line is it a full replacement for the turbo system on the msp
Yes, it is a complete replacement setup for the stock MSP oil lines including restrictor. It also has new coolant fittings, you supply the hoses to clamp to the new coolant fittings.
Brand new in package, never used.
i sent u another pm... what brand or where did buy the oil line kit from
Replied via PM, but for everyone's benefit:
I ordered the kit from a company in Japan. I have checked and it definitely replaces the MSP stock setup perfectly. All the necessary fittings, restrictors and gaskets are included.
