Ok so now that I am back in the states I decided to look into wheel fitment on the 2 to give people a better idea of what fits. This is all with the stock alignment on the car.
Here is the stock wheels on the car.
As you can see there is a lot of room for the wheel and tire to be moved outwards. Here is the same corner with my 15X7 +40 offset TD's with 205/50/15 RE-11's
As you can see there is still some room for the wheels to be moved out before the tire is going close to the fender. I then looked at how it fits with the strut.
Here there is 0.5" of clearance between the strut and the wheel. I then turned the wheel and looked at how close the inside of the tire gets to the inside of the fenderwell. First I turned the wheel all of the way to the left.
The tire has about 1" of clearance from the inside of the frame. You can also see how the frame is cut out in that area for tire fitment. It runs up pretty high, so even with compression the tire will hit the top of the fenderwell before it hits the inside when turning. I then turned the wheel to the left.
With the wheel turned to the left there is plenty of space again about 1" before the tire would hit the fender. So from all of this it is clear that you will hit the strut with the wheel before you hit the inside of the fenderwell with the tire. This is assuming you use a 15" wheel, and have a reasonable tire, no 275/35/15. I then checked all of these with that corner of the car lowered half an inch to see if anything changed. I didn't think it would. Here is how I lowered the front left.
Here is another look of the wheel and tire but with the front corner lower by 1"
Adding some negative camber will obviously help the fitment a lot. I will be looking into that on another day though.
