Installing springs + struts
callITaDAY
2003 MSP #14
I'm having a great time putting on my struts. The first strut's bolts are soaking in pb blaster, cause those things are frozen on. Well, this is fun...
I'd call it a day and let them soak for a bit longer and wait tell you have a friend to help you with proper tools for situation your in right now.
my buddy and I just used his impact with a little pb blast (didnt even soak them, just sprayed some on there and hit it with the impact) didnt have any problems taking out the struts and putting my ground controls on. impact is amazing!
I was using a breaker bar, two of the strut bolts stripped so I'm going to have to cut them off. I'm going to soak everything in pb blast today and take another shot at it tomorrow.
Heat gun, pb blast, nut extractor set and a big sturdy breaker bar. Always works nicely.
update: Got the two messed up nuts off with a nut extractor. I took the car to my friend's shop and an impact gun took the rest off no problem.
So, do yourself a solid and use air tools.
