2011 Mazda 2 with 275/35/15 Hoosier A6 with 15x9 6UL
corytomo
11 Mazda2, 91 SSM Miata
Car: 2011 Mazda2 Sport, all stock
Tires: 275/53/15 Hoosier A6
Rims: 15x9 6UL +36mm offset
Front:
main.php
main.php
main.php
Now for the inside pics:
main.php
main.php
Bottom line: Rim hits stock shock upright, tire rubs shock body. Would require at least a 5mm spacer, but it will protrude from the fender at least 2".
Rear:
main.php
main.php
main.php
Bottom line: Will fit without spacers or inside rubbing. Would require fender flares or massive fender rolling.
Is is the 15x8 6UL that fit without rubbing? or the 7.5. Could look bad ass with a lower and some extra work :D Thank for the pics!
Looks like a RWD pro stock car with that much rubber back there, lol
Awesome
-Derrick
Shawner, the 15x8 and 15x7.5 fit without any clearance issues. I need a drop, badly!
Derrick, it does! That could be your next project... RWD LS6 mid engine Mazda2! :D
:like: :)
Thanks for the pics, I was wondering if they'd fit!
lol nice so with that wide of a rim I take it youre not in HS. Im looking to buy 15x6 or 7" rims and see what size I can get of a hoosier a6 or toyo r1r that would work nicely to stay in HS.
that's bonkers, I'll make you some molded CF fender flairs if you make that your daily driver tire combo
I'd love to run 275 hoosiers daily! But it would probably cost too much, wear too fast, and rain would scare me! :)
