How-To INDEX
Rotus
07 MS3
Can I get a sticky for this?
I'll try to get as much as I can in here. It'll probably take a few days so please bear with me...
Going to do this reverse chronological order first, then probably re-order alphabetically.
emblemless grill install
independent fogs on a gt
LED lights install
turbo timer install
diy mudflaps
catch can install
transmission mount install
coilovers/sway bars/camber arms install
rear motor mount installation
molding/emblems removal
service manual downloads
independent fogs with no firewall wire
O2 sensor removal
tpms reset
torque damperinstall
TCS/DSC complete off
boost gauge in driver's vent (DIY)
boost gauge in vent-pod
boost gauge in defrost pod
remote programming
intake resonator removal
cabin filter replacement
HID ballast placement
rear motor mount (DIY)
cat-back exhaust install
shock/strut/spring install
angel eyes install
subwoofer aftermarket wiring
amps and speakers (Bose replacement)
radar detector hardwire
ptp kicker mount install
transmission fluid change
speakers, front replacement
grounding improvement (car audio)
badges, painting
catless cel fix
wheels, how to paint
brake pads, front how-to change
wiper blade, rear replacement (DIY)
brake pads, rear how-to change
badge, front removal
glove box, rattle elimination
sirius sattelite, OEM installation
auxmod, installation
map clamp, diy and installation
dash, rattle elimination
shifter, diy stiffening
turbo timer, apexi install
headlight/tailight tinting
trip computer, unlock on non-gt
oil filter, spin on conversion "how NOT to"
oil, changing
shifter, short shift plate diy
door panel, rear removal
key, flip key part #s
subwoofer, diy enclosure
side mirrors, heated and puddle light diy
turbo inlet pipe, PG tip install
spark plugs, replace
shifter, shorten without a plate
cdfp, install
headlight, hid install
cobb accessport, "unbricking"
audio, external amp install for bose
headlight, hid re-aim
intake, cp-e nano install
bypass valve, forge install
towplate, diy
gauge pod, cp-e center install
gauge, prosport mechanical boost wiring
center console, removal
various, krstym's garage
blow-off valve, turbosmart set-up
camber links, rear install
seat, racing install
bulb, dash bulb tests
side mirrors, heated install
alarm, oem shock sensor upgrade
front bumper, removal
balance shaft, delete
side moldings, removal
storage cubby, shelf liner diy
sway bar, front install
rain visor, oem install
audio, sound deadening install
boost controller, manual install
downpipe, turboXS combo install
intake, aem install
boost controller, manual with atp fuel cut defender
bumper, rear removal and reflector swap
ecu, xede interceptor install
gauge, pg mold-in pod install
wheels, painting diy
FMIC, Protege Garage model install
that's up to page 6
Thanks. I still need to finish listing, then alphabetize. I've been checking some of the links to make sure it is actually a how-to and not a question. If anyone finds errors, let me know and I'll update the thread.
Great post, thanks! Just an FYI though, the "lower console removal" is just a question with no followup.
Chris
Good Day Rotus
Can't find a diy on EGR cleaning useing search for a 08 MS3, do you know of one please?
I don't think there is one on here. Maybe I need to write one now that I've done it twice.
I can sort of do it from memory:
You'll need a good set of tools and some basic knowledge of how to get around your engine bay. You will also need some wire brushes (straight and bottle), carb cleaner (do not use brake cleaner) a small plastic cup to catch coolant, extra coolant and the EGR (and throttle body) gasket if you don't want to reuse your old one. Use gloves and eye protection.
Remove the intake, battery box and turbo inlet pipe. Be careful when removing the inlet not to break off the small vacuum nipple near the back. If you want to clean the EGR recirc pipe that goes from the EGR to the intake (highly recommended) you will need to remove the intercooler and cold pipe. Once you have all that stuff out of the way, you can get to the EGR valve. Unplug it. Place the plastic cup (or a funnel and hose to a bucket) underneath it and remove the water hose and the two bolts that hold it to the head. Now remove the top cover of the egr valve and place the whole sheebang in a cup full of carb cleaner and let it sit. Every once in a while, use your thumb to actuate the valve to get the cleaner around all parts of the valve.
While the valve is soaking, remove the cold pipe and elbows to get to the throttle body. Remove the throttle body (4 bolts) and you should have access to the far end of the EGR pipe. Unscrew the big nut that holds it onto the intake manifold, then the 2 bolts that hold it to the head. Carefully remove carbon built up behind the head side of the pipe if there is any. If you have a rubber stopper, plug up one end of the pipe and fill that thing with carb cleaner and let it sit.
At this point, I cleaned out the tunnel in the intake manifold that the EGR gasses passed through and it was filthy, you can do the same by blowing carb cleaner in it and using a bottle brush. You won't get all the way through, so you'll have to go from both sides. Make sure to clean out anything loosened that may still be in the tunnel. I sprayed carb cleaner from the intake side to a cup on the pipe side. Make sure you clean the residue from the inside of the manifold. You can use a mirror to look in there, it's dirty. If you have a small pool of oil in there, you can see why some people run a catch can. Once you have the intake clean, you can finish cleaning the pipe and the valve with the wire brushes. I got a multipack of them from Harbor Freight. When cleaning the valve, make sure to turn it so you can clean all sides of it. You should be able to turn the valve by partially opening it with your thumb while turning. Make sure the valve operates smoothly with out sticking.
Reverse for reassembly and don't forget to add coolant.
Does anybody have a walkththrough on installing autotech fuel pump internals? Ive been looking but cant seem to find one.
