just bought my mazda, love it, but another car's issues have followed me .. when it rains the driver side floor is wet, I think its from the door area approx 20cm from the front, any ideas what I need to plug up or clean up
thanks
Theres a bad seal around where the clutch goes through the firewall. Get under and have a look at the metal bracket around where the clutch goes through, when u find it just put some silicone on your finger and smear it around the outside, if your cars an auto im not sure.
Check your sunroof drain lines. If they're clogged, try blowing them out with some low pressure compressed air or take some wire and push it through them. I have this problem on my accord.
Mine was leaking right under the wiper linkage housing. It was rusty and I had to put a ton of silicone there. It took a week to dry the wet carpet + floor. I Had to dismantle that carpet too in order to wipe the water. Good luck.
