I'm running dry on ideas.. need some help thinking of other possibilities...
I've got a rough idle that will nearly kill the car on start, though once it gets going its fairly stable. The larger problem however is that it I have no power during accel. I can floor it and it will move but doesn't punch like it normally should. This all comes after repairs in order to fix a Cyl-1 Misfire (which I admittedly sat on for a few months
) which I think may have been caused by either a bad spark or faulty injector. Here's the current state of the engine, note how violently it shakes on that initial acceleration:
Video 1 (Int)
Video 2 (Bay)
Things I've replaced:
Video 1 (Int)
Video 2 (Bay)
- New Injectors x 4
- New Coils
- New Sparks
- Fuel Pump + Fuel Pump Strainer
- Fuel Filter (or more accurately the entire plastic housing the pump sits in)
- Replaced MAF
- Replaced IAC (motor mechanism only), cleaned out the aluminum housing.
