CORKSPORT LED DRL Kit
2006 Mazdaspeed 6 Grand Touring & 2004 Mazda 3s (5dr)
OK guys, I purchased the CORKSPORT LED DRL Kit to replace the stock fog light bulbs in my 2006 Speed6.
http://www.corksport.com/corksport-led-drl-kit-h11.html
I have the stock H11 removed, but the LED fog bulb will not go in all the way. There is a metal hood in the fog light housing that is blocking it.
Does anyone else have these installed? If so, how do you get the metal piece out?
As you can see in my pic, there is a small phillips screw that is inside the housing. But how do you get inside the glass to unscrew it?
I dont want to force it in cause it could damage the LEDs.
I'm hoping that Corksport has a solution for the application of their product.
You should be able to fit it in there without forcing it. If you get a chance OP give us a call at 360 260 2675.
-Derrick
