just pick up a JL 8"
Okay, question:
I have a loud "whistle" coming from under the hood. I need to investigate it further, but it's a fluttering whistle, only when the car is under boost. It used to only be when it was cold outside and the car was cold, but now (in Florida) it sticks around for a while, even after my water temp has come all the way up. I don't smell any strong exhaust, but I'm guessing its a gasket around the turbo or something along those lines. Any ideas?
Whistle could be your WGA.
or it could be your turbine blades starting to scrape against the housing lol
I have been experiencing this lately as well. I am thinking it is either the turbo about to die, or possibly a leak somewhere.
Wow, busy day for me and my MSP. Finished up the J&S install, fine tuned on the Microtech, upped the boost, got the J&S dialed in, and tuned the methanol a bit.
Yeah, I think I narrowed it down to a leak on the right side of the exhaust manifold gasket. My guess is when they replaced the broken stud over there, they didn't replace the gasket like they were supposed to. Now it doesn't fit correctly and is getting worse with age...
Just bought a jdp replica lip
attached the recirculating fitting on my bov and attached the bov to the pipe, read the turbo timer instructions sort of, they are in japanese but the pictures make sense I think.
I am trying to switch to a recirc setup once again. What kind of hose did you use and where did you find it? Also I'm looking for a pipe to weld onto my intake.
Where? I have been looking for one for months now...
