car went nuts again on the way home p0300, reset the ecu and it went away...seems to happen on warm up
with the help of a friends press, i got my new wheel bearing in. had some issues getting the knuckle back on but it went after a bit. messed up the balljoint pinchbolt so just need to pick up a new bolt to replace it tomorrow and ill be on to some smooth driving :)
first replacement bearing that went in was faulty so i need to send it back to rockauto. lucky for me I ordered two bearings so I was all set!
Sweeet.
How long did it take you from start to finish?
Nothing new, just decided to have some fun with the sad fact that winter just doesn't want to LEAVE! lol
Sweeet.
i had some hiccups with getting the knuckle off the car because I was being a retard, but with all going well getting the knuckle on and off should take under an hour.
then setting up for pressing the bearing took us about an hour to find the right pieces of metal for propping up the knuckle. but when we found out the replacement bearing was faulty it took us about 15 minutes to press it all out and re-press in a replacement.
How did you know the bearing was faulty? (Lemme guess, Beck/Arnley part? :P)
started it with part of the new exhaust, sounds pretty awesome
cant wait to get the 440cc injectors in and drive it for the first time....should be awesome
