DDM Tuning Apexcone Raptor HID Kit - $30 plus shipping
Flip the wires. Sounds dumb, I know, just do it. Should work; had to do it with my fogs.
i will see if i can flip and wires but i think everything can only plug in one way and i went with the h4's cause i couldn't find affordable p5 housings (someone hit me and busted up my headlights and i just bought a set of sedan ones)
are they the high low? if so there is only one way, but idk if they are just wires then it is easy to switch. post pics of the harness and the adaptor.
i bought the low beam h4 kit cause i had to buy two new headlights due to an accident and p5 headlights are crazy expensive. the h4 kit seems to plug right into the p5 wire harness but do i need to rewire the p5 lowbeam in order to make it work with the hids? i will try to post pics tonight
figured out the problem i just had to repin the p5's lowbeam bulb connector to match the h4s pins and it worked super easy! here are some pics, i will post pics after i align the headlights.
232323232%7Ffp63396%3Enu%3D4495%3E27%3A%3E258%3EWSNRCG%3D32%3B3%3B3%3A%3A93349nu0mrj
a test fit with my bumper and grill back on
232323232%7Ffp63395%3Enu%3D4495%3E27%3A%3E258%3EWSNRCG%3D32%3B3%3B3%3A%3A94349nu0mrj
close up of driver side light
232323232%7Ffp63282%3Enu%3D4495%3E27%3A%3E258%3EWSNRCG%3D32%3B3%3B49238349nu0mrj
Close up of passenger light, i need to have the fender properly fixed but at least the light fits and works now :)
232323232%7Ffp633%3B4%3Enu%3D4495%3E27%3A%3E258%3EWSNRCG%3D32%3B3%3B3%3A%3A96349nu0mrj
pic of the lights installed before putting the bumper on, i'm going to leave it off i need to find a way to hook up the lights on the far outside part of the headlights, i will wire it into the turn signal or parking lights not sure which.
232323232%7Ffp63258%3Enu%3D4495%3E27%3A%3E258%3EWSNRCG%3D32%3B3%3B49255349nu0mrj
I'm going to put the ballast on the passenger side on the side wall here
232323232%7Ffp63264%3Enu%3D4495%3E27%3A%3E258%3EWSNRCG%3D32%3B3%3B3%3A%3A9%3A349nu0mrj
and the driver side one i think will fit nicely on the side of the fuse box
I got to post pics of mine....
Just got done a 55w 8K hi/low on a cobalt. Another clean install and so dam bright.
those clip things on the front bottom side of the head light have to come off to get the light off i thought and i needed to do a little fixing on the passenger side behind the light in order to make a headlight housing fit where it is supposed to go cause of the accident
Yes but it will save you the cost of having to buy a replacement HID kit down the road, here is how I wired mine:
I have an aftermarket battery tie-down so yours might be slightly different
The relay is on the left, it comes with a bracket to bolt down wherever you want it
Close-up of the positive wire on the positive terminal
Close up of the ground for drivers side ballast and misc. connectors, make sure the location where you install the ground is stripped down to absolutely bare metal
Drivers side zoomed out view
Wiring tucked behind vanity cover
Harness zip tied to another connector for support
Another zip tied location for support
Close up of passenger side area
Passenger side ground point
Passenger side zoomed out
This isn't the cleanest install ever but everything is easily accessible in case anything happens.
Pictures don't work...Could you please fix it :/
lol kinda ironic someone just bumped this thread up today.
I finally decided to get a pair, ordered it a few hours ago.
5,000k.
Are they pretty straight forward to install? Just pop out the old bulbs and throw in the HID bulbs and plug in a few things? :)
5,000k.
i hope they are lol i ordered my set today too! but i got the 6,000K ones...i shouldve gone for the 4500 or 5000
I want blue ones.. But I read earlier posts about how the visibility sucks, so I went with the 5,000
i just looked @ my order that they sent to my email and noticed that i DID order the 6,000k and not the 5,000 -_-
idk if im happy or pissed about that.
i don't do much highway driving at night, anyone think I'm gonna run into problems with visibility?
