Of course, but I always have to consider that the car needs to pass PA emissions. I need to keep both cats and every-day drivability. The best ECU change I could hope for would be the MP3 ECU. My understanding of that ECU is that it MOSTLY increases the ignition advance. If I did increase the CR and use the MP3 ECU I might be pushing the limits of its range; previous work to raise the CR meant retarding the ignition for better power.
I'd be hoping that I could get the car to pass emissions with a milled head, a VTCS-removed intake manifold, MP3 ECU, and JDM intake & exhaust cams. I know it won't ever be a BP but it will help me stay entertained. I just like to fool with things. If I ever win the lottery, I'll turbocharge it then.
I'd hope that the increase in CR & the bowl blend might get me another 5 WHP. Again back to the specifics: with 0.025" off the head, does anyone know how close the valves might get to the pistons? Or would I have to clay-check everything? I would think that since the cams are OEM in other places AND 0.025" is the factory service limit that it would be fine.
