theeheteroclite
Okay, so I'm finally fighting a few problems on my protege 5 after owning it for several years.
For one, my air intake hose is cracked, and will need to be replaced. Normally I would be asking for a good aftermarket upgrade, but I'm unemployed right now, and have to do things on a budget. Can anyone suggest a cheap place to get this?
Also, my engine threw a code the other day. It may be related to the cracked air intake hose, but I just wanted to see if that's even possible.
I took it to Autozone, and it said: "lean air/fuel ratio bank 1", and gave me these suggestions:
Low fuel pressure
Large Vacuum leak
Dirty/defective MAF sensor
Engine Mechanical condition.
The car wasn't running rough or sluggish when the check engine light came on. Do you think it's possible that the air hose being cracked could be the problem?
Thanks
Low fuel pressure
Large Vacuum leak
Thanks
