Aggressive fitment anyone?!
any good links to some cheap camber plates?????
Nope, sorry. I'm sure someone in here should, but I have tried to avoid looking for parts while I have no monies... When I pickup coilovers this winter/spring I will hopefully get pillow tops and the whole 9 yards as well. I still need to buy winter tires, and spend a chunk of change on a new alt, a/c compressor, belts, heater core, water pump & timing belt kit, asap. Boooo
the wheels i want either come in 17X8 +48mm or 17x9 +35mm... will the 17X9 fit? i would probably have to roll my fenders a crazy amount, and adjust the camber quite a bit. anyone with this set up? what suspension? what tires?
or actually i just found these...
http://www.wheeldude.com/catalog/product_info.php?products_id=5939
that might work great, and maybe some 5mm spacers later
Yes, they'll fit. That's my current setup right now, but you might need to stretch your tire. I went with a 205/40. 0 camber and fits great. I say it's the perfect setup if you want to be flushed in the front.
Nice! Anypics? More info on setup? how low, how much rolling, rub?
He was reffering to the 17x9 +35, in your link though if i read it right, its a 17x9 +42, and that size, i dont think will fit because its goin to hit the strut. + 35 should be the highest offset youd want on a 9 inch
yea thats what i was getting at, i dont want +48 becuase thats not even near flush, and i was saying if the 35 had no chance of working maybe the 42 would be a happy medium... so the +35 on a 9" wide wouldnt hit but the +42 probably would?
the 35 works, i dont THINK the 42 would hit...i remember a guy on here test fit 9" +48 rpf1's but he used a spacer..i cant remember how big though
i would go with the +35 9", run 2* camber, fenders rolled flat, 205/40, and your set
I can only speak for a bc suspension setup in front. I measured clearance with tire and without tire and it was only credit card clearance for. 9 +35. I rub only because I didn't roll my Fenders. It all eventually rolled itself. Rubbing was minimal. It also depends on what tire you get too..
varsstoens wheels +12 18x9s
thats what your gonna run? good luck, your going to need some flares or a crazy pull
oh s***, didnt realize it was that close
well then the +42 def wont fit
i know that with stock protege5 struts you can run a +20 with pinky clearance from the strut in the front. i tested it out
is that with stock struts and springs? i am probably just getting s-tech springs on illuminas. got to dump some money into the drift machine...
My wheels are already done at the powder coaters woot! (centers PC'ed white and the inside barrels bead blasted)
