There is a valve under the dash that controls the fluid flow from the engine cooling system to the heater core inside the car. When you turn the temp control on the AC unit it opens or closes this valve with a cable running from the control to the valve, if its not hooked on properly this may prevent the heater from getting adequate flow from the motor. I'm not sure which one it is though, there is a cable for the heater's valve, and one for the floor/dash/defrost vent selector too. If I'm not mistaken you can access both by removing the glovebox, one is right behind it, the other is more centered in the dash. I would drop the glovebox and take a look at these cables. They should both move an actuator at the end of the cable when you turn the control knobs, if either one isn't hooked up or hooked up improperly that could be your problem. Hope its as simple as that. Good luck!
