- 2001 Mazda MP3
awesome write up... and seems like it would be a good idea to do the catback install at the same time to avoid cutting it when taking the stock one out.. hmmm
I got a 10 length of 3/8 hard wood dowel and drilled a 1/16 hole in the end. I then hammered the allen wrench into the hole making a ball-point allen wrench with a 12 reach. To use this tool, you have to remove the plastic caps at the top of the rear wheel wells that house the rear seat belt reels.....
It's less comfortable and offers much more control.
The suspension doesn't move much at low speeds. My commute recently changed from 20 miles of twisty back roads to mostly crowded freeway driving. At 20-40 mph on a rough California concrete slab freeway it's awful. I feel like one of those bobble-head dolls. The bumps are gradual enough and the speeds low so the suspension does not move at all.
OTOH, once you get to speed on bumpy back roads, so you are hitting the bumps faster, the suspension works. The faster you go the better it works. And it's always great on smooth roads.
The handling is greatly improved... no more wallowy feeling and less leaning in corners.
If you drive a lot of bad pavement in traffic I would recommend going with Koni FSD and a set of thicker sway bars. That won't lower the car but the shocks will fix most of the wallowing due to insufficient stock damping and the sway bars will have the car cornering flatter.
Digging up this thread from the dead, I have just had a failure of the left front strut on my car. The attachment tab on the shock where the ARB link attaches broke off. I disassembled the strut and found that the body of the shock is also fractured where the tab was welded on. I have to replace the entire coilover setup. (argh)
This problem may be a component compatibility problem. The Hotchkiss ARB is quite stiff plus I added AWR links which I think may be a bit too long. This combination may have overstressed the mounting point. I am analyzing the geometry so my new setup won't have this problem again.
I took out the Mazdaspeed (Kw made) complete kit and replaced with a new kit from BC Racing. When I installed them, I shortened the front AWR links about 1-1/4" by cutting and re-welding. They seem to be fine. As for adjustment of the shocks, I found with the Mazdaspeed ones, as well as the BC Racing, they get stiffer as they break in over the first few thousand miles. I re-adjusted the Mazdaspeed ones a couple of times, and I have tweeked the BC Racing ones once, and will do it again soon. Each adjustment was in the softer direction.Hi Rotus, Did you replaced your front shock? How did you fix the front end links issues? Did you go back with stock end links or AWR's? I am thinking of getting Kw V1 or V2 and the Hotchkiss front and rear sways. Mine is a DD so I am leaning towards V1. Just curious, once you pick your settings on the coilovers, how often do you readjust them? Greg
As for the rears, I am about to change out the AWR links in the back for the stock ones, at least as an experiment. I still get a rattling from the rear, even after replacing the bar bushings & mounts. I think the joints have gotten loose. If it still rattles, I am going to have to really tear into the rear suspension 'cause there is something not right about that noise.
both BC and MS, and I presume the KW, can have the ride height set anywhere from stock down. I set mine about 1" below stock. Expect to scrape the front lip anyway, there are lots of driveways, dips, parking lot thingies etc. I think most MS3s get the spoiler scraped up eventually even at stock height. But I agree setting it so at least your own driveway can be navigated is good practice.Thanks Rotus. I think I will stay with the stock end links.
Any thoughts on the BC and MS coil you care to share? I don't want to lower the car anymore than I have to. My driveway will not allow anything over an inch lowering or I will scrape the front lip. The MS and KW lower the car the least. I was told that the BC can be adjusted to stock ride height. Is that true? Greg
