dumb question, what's the FIC stand for?
got it. why not just go standalone at that point?
because an ECU does a LOT more things than ignition and fuel... and a standalone will never pass emissions. Not to mention the cost difference factor.
thanks, everything was mostly trouble free, had to basically take the reflector cups and dremel spacers out of them, to put between the projectors and the reflectors plus had to get some home depot rubber gaskets.Looks good bro!
actualy a standalone haltech with the pnp harness from sam can be wired to only control timing and fuel so when it comes time for inspection all you have to do is unhook the pnp harness(looks like a T) and remove the haltech and plug in the stocker to the factory ecu.
The head is back on. Timing is done thanks to my boy Simon. All that's left is the intake mani and turbo and piping.
Getting it probably tuesdayish. About to do a compression test before putting the car back together the rest of way. Wish me luck
