Then how will you put a new one on??? All you do is take out the intake, then there are two bolts underneath the throttle body...very easy to do...
Just put your hand underneath...once you get the intake off, just put the socket under there and turn...there is also one plug...I think they are 12mm bolts...
Other HID ballast died... wtf... I haven't even sent in my first dead one... time to find a new kit other than ddm
27"x7"x2.5"
Instead of cutting all kinds of stuff I can still retain my fogs, washer bottle, and not have to cut the crash bar.
I don't see how it'd be a problem. Are you going to retain a fan there? That could be equally beneficial. Trigger it on high intake air temp...
You may have some issues with fitting the pusher... depending on how the IC is really mounted. You're running the standard puller radiator fan, right?
Two slim pullers on the Radiator.
Going to pick up the hole saw tomorrow. Day off so im going to enjoy it. lol Ill sleep when im dead.
Once I get this out of the way ill be upgrading the exhaust.
installed MP3 ecu... man... that thing hurt. Cut my hand..even while wearing gloves, but finally got it in there. Havent driven it much..just got to take it on and off the highway...feels good so far.
nice dude! glad your liking it so far, except for the cuts.
