yea u could throw 14s on our cars and they still will get smoked by moms in minivans (unless your turbo!).
can they do 110?
Anyone got the How-To for installing a KLZE done yet?
Tire weights vary quite a bit. High performance super low profile tires have super thick side walls and are typically heavier. That'll have to be verified though.
I read a Motor Trend Article, probably 10 years ago when the super modifying craze was taking off and the best performance on the stock VW or whatever they tested was with 15" wheels and good tires. All the same wheel and tires from 15 to 18 inch. Remembering that was some of the motivation for starting this thread.
As far as KLZE, is it from an 01 or 02 626? Those are OBII and should work right? Ah hell, I'll just do a search.....
I saw that same article, but I don't think it was ten years ago. I'm pretty sure I read it recently (unless I read an old magazine at the docs office or something)
In either case, it makes perfect sense. Proven in truck form with. My ram. Got the bigger wheels/tires and I can't tow as much. Takes more power to turn a larger circumference wheel than a smaller one
Hint: There is a link to the article in the last quote which was the third post in this thread. It was Car and Driver April 2010.Car and Driver proves you are right... Effects of Upsized Wheels and Tires Tested - Tech Dept.
^unless you get bigger wheels that are lighter, like rpf1's
can they do 110?
