i have also done it, but radiator was off my car!
Did your cooling fan ever happen to stay on for like 10 minutes after shutting the car off? i just ask because my dads jeep cherokee did one time because the relay was going out, the car started to overheat after that until relay was fixed.
Im a honda guy and HONESTLY, my brothers mazda speed always seem to have problem back n forth. The suspension to brakes, coolant, etc. Although its pretty fast and i didnt know he had that 3.5k forged block with the new mazdaspeed manifold. Other than these type of problems it drive nice. GL on your coolant issue man.
Had the same exact problem last month, but I also had oil in my coolant. Totally thought it was a head gasket.
$400 later for diagnostics, they told me motor was fine. Changed my tstat and cap and haven't had a problem since.
Are you sure you got the right radiator cap? I think its supposed to be like 1.3bar or something like that
i dont see how a thermostat and cap can fix oil in your coolant.Had the same exact problem last month, but I also had oil in my coolant. Totally thought it was a head gasket.
$400 later for diagnostics, they told me motor was fine. Changed my tstat and cap and havent had a problem since.
So is the OP getting oil in his coolant or not? Like a bunch of the other people have said, head gasket and water pump would be my best guesses. I had an overheating problem due to me forgetting to plug in the main fan and the car would occassionally get a bit hot. Luckily this was in the winter. This weakens all your coolant hoses. I had three different hoses spring leaks on me in three different spots. Take care of the excess heat.
How many miles are on the car? Has the water pump ever been changed?
....uhh not suppose to use a garden hose to flush your radiator....
