What have you done to your Mazda6 today?
in time.. been more MIA because I'm pushing really hard to get the shop open this coming week.. one day ill just drop like 60 pictures into my build thread.. :)
and also depending on how close this Hurricane comes to us, depends on if we have alot or alittle damage to clean up afterwards, which could effect the shop opening due to no power, which i hope we avoid.
So here is a quick picture of my double din install. It is not entirely finished because I think one of the wires must of unsoldered when I was pushing the faceplate in. Anyway the ac works the only problem is I cant switch the center button to turn the air from outside and inside. This will be fixed probably next week. Other then that I just need to get my bypass module so that I could change the display options which are locked right now so that I could select an amber background. Once its fully done ill put up more pics.
looks sick!
Whoa, that looks nice!
Spent the afternoon doing a good once-over on the car. Cleaned the door jambs, trunk, engine bay and cleaned/protected everything inside really well. Found some stains on the headliner that I got rid of as well (damn women!). Gave it a good wash with some new products and got it ready to show to the buyer tomorrow.
I may rotate my tires in the mean time, but haven't got around to finding enough motivation for that yet.
I got all hopped up on 5 hour energy and its an unbelievably gorgeous evening, so I washed the car. I've never seen her so clean! This was just a wash w/ Meguiar's Gold Class. I've got Optimum Opti-Seal still going strong from a month ago. I don't even want to drive it, I just wanna look... and feel...
so very clean! can you plz detail my car EVENT? lulz.
yer car is begging to be lowered! :p
i KNOW. but I need an intercooler and some sort of exhaust mod to make it sound meaner. so much to do so little time... I'll keep my eye out for some used coilovers. I wanna do things right.
Just got a call that the guy who was going to look at the car decided to bail. Oh well...
too bad :( at least your car is clean and happy right now!
Went to turn my a/c on this afternoon and all it does is blow warm air! I heard some kind of clunk sound come from the right front of my car this morning. After I got to work and tried the a/c I got out and looked under the hood. Both the low and high pressure side have absolutely no pressure. I cut the engine off and looked at the pulleys. The a/c compressor pulley apparently has a plate that bolts to the outside of it? Maybe to drive the compressor. Well anyways, that was just laying there against the frame detached from the pulley itself. So I put my hand down in there and let it drop down. I found 1 bolt laying at the bottom as well. anyone ever had this problem?
I need to check my motor mount bolts, I think one isn't tightened all the way. Tomorrow I'm going to rotate the tires, clean the wheel wells, and enjoy it.
