hey everyone I have an 03 mazdaspeed protege and I'm experiencing some problems, when Im shifting as soon as it hits 4500 rpm the car cuts... could it be because i changed the upper and lower o2 sensor or could it be that my turbo pipe is damaged?
any kind of information would be greatly appreciated! thanks
fuel cut, you will need some sort of piggy back to solve the problem.
SSAFC
I agree on the SSAFC, I love mine and if you get one, you will be glad you did
swapped my MAM midpipe for an SLS with a local P5er (the J section overlapped with his header, so we did an even trade), and swapped my DG fiberglass for his OEM grill.
used my msp as a moving van, not the best but it got the job done. I also had a lot of wheel hop from my passenger side. Don't know if it's not enough gas when letting off the clutch or what, but never really had that before and i've been driving it for 4 1/2 years now
now i look like prdracing
Ha, if I could retell everytime I have used mine to haul things not intended to be hauled in a sportcompact sedan! let's see, I used her to transport every piece of lumber when I extended my deck. Nothing like 16' 2x6s hanging out the back of the car. I had to remove the passenger and rear seats for that one. Then you have the bridgeported 13b hybrid and trans that I picked up in South Carolina. That was interesting change in the weight balance of the car. You are right though, it's not the best but it sure gets it done.
2.4"/60mm is plenty for these cars. and corksport makes quality stuff
Well boost gauge is reinstalled, Wideband is wired up, oil pressure is wired up. Only 1 more to go D: and thats oil temp. Its wired up but the gauge isnt in and the sensor isnt fitting yet D: Working on it though.
