Lindsey Racing Liquid to Air IC Pipe
I've looked at these in the past as they are exceptionally efficient. The downside is all of the extras required to run it. Typically you use a water reservoir in your trunk though depending on your pump you can use coolant instead of water. You could also utilize a radiator and install it similar to an FMIC and bypass the reservoir system cutting down on the tubing required. Most that I have researched are cheaper than aftermarket TMIC's and FMIC's, which is appealing in itself.
