Mazdaspeed2oo35
600whp - 600wtq at 30 PSI
sweet, you like them?
I sure do along with all GTspec Accessories bars and braces and AWR Endlinks, they are the best bang for the buck when it comes to suspension.
How much clearance did u get in the back? Im going to go with 5mm spacers So i think ill be at +45 with them. Im hoping I dont need to raise the car.
I'd check your CV Joints & tie rod ends. Wheel bearings typically make noise all the time, not just in a turn. And typically, if it's your passenger wheel, when you turn to the right, the noise will go away because load is placed on the outside wheel during a turn. And the inside wheel gets most of the load taken off of it, so the bearing grinding will go away.
well just picked up some used Pirelli P Zero tires for the rx8 rims...
these tires come stock on lambo's...
went over a set of railroad tracks a lil fast yesterday and made myself a lil boost leak... oops.
and my eyelids showed up today.
I know I should post this in the perfomorance section but figured get more replys here quicker lol. Is anyone running the Perrin J-Pipe back exhaust I'm trying to order exhaust and like the clean look of the muffler vs a big muffler like the Vibrant even though it's my other choice. If goin with the Perrin will be ordering a Corksport downpipe as well.
what are you air brushing on them?
Airbrushing stock colr paint ripping open to reveal the Carbon beneath. I think they stand out like a sore thumb if the door and front bumper is left in paint...
Are you doing the air brushing yourself?
Prepped and Primed my CF fenders fro airbrushing...
