It appears that the manual transmission is leaking at the bottom of the housing after changing my 2001 Protege 2.0 manual transmission fluid with Redline 75w-90. I see some small, occasional drips, and it looks like the housing and the surrounding areas on the underside of the car all got soaked with it. Is this a bad sign, or will the seals be fixed with the new fluid soon? What should I do? I've already made sure all the bolts are tight.
