How much were the tires (total price), and where did you have the work done?
It cost $600 installed + tax at Quality Discount Tire in Kensington, MD.
If I may asked does this price includes any of the following?
* lifetime rotation/balancing
* road hazard replacement coverage
Thanks in advance for your reply.
I don't think so. This didn't matter much to me as I get my tires rotated at the dealer when I get my oil changed.
Radial Tire in Silver Spring has lifetime rotate/balance.
Has anyone with Continental ExtremeContact DWS tires noticed a decline in fuel economy? I'm thinkin that my pressures may be too low with this new size. I asked the shop to inflate to 36psi.
Ours was the same as always, did you get the stock size? I fill them to 40psi.
We did 1600 miles on a vacation in july averaging about 28~30 mpg loaded with two kids two adults, luggage for a week, golf clubs, and rear carrier with bike and cooler. These are great tires from our experience. Though there was a section of concrete highway that had a harmonic, noticed it to a lesser extend with my protege5 running toyo proxes tires.
Our price was $660 with full warranty from Big O Tires.
you should be ok at 36 but keep checking it once a week. I would not go past 39 though. 40 is too high. You'll be fine between 36-39. I keep mine at 38 and i haven't had any issues with uneven treadwear. the ride is a little firimer, but not uncomfortable. I didn't notice much of a difference in handling other than a tiny bit more oversteer in the beginning of a fast turn
Could it be that the new size is affecting my odometer just that little bit?
yeah probably. Use an online tire calculator, if they're bigger you get fewer rev's per mile, are going faster than what the speedo says so.... My DWS's were stock 205/50/17's.
^^^ KUMHOS!?!?!?!?!?!?! Are you joking? Even if they felt great, sounded great, handled great, etc. I would never, ever buy something that my life depends on that is made in China. How people can so easily forget the melamine in the baby food, lead in the toys, steel pipelines blowing up because of flawed steel, etc. is beyond me. Don't buy Chinese crap just because it's cheap. Sorry, I digress.
It's sad that it doesn't seem anyone here listened to you. I have used multiple sets of these on my Saabs which run very similar aggressive suspension setups with lots of neg. camber. The HTR Z-III's are the best tire that money can buy if you like grip and need a tire that can handle the setup without wearing funny like most all other tires will do on the 5.
The secret to these HTR Z IIIs is the solid inner tread line. Because it is solid there is no way for it to cup. That means more of your tread can be used since the wear is more even.
How many of you guys have replaced your tires because the inner portion was done but otherwise the tread was in good shape? The design of these Sumitomos allows for an even softer, more grippy, tread to be used without the mileage hit that you would see in other high performance tires.
The other thing is they are incredibly quiet and for a performance tire very comfortable. Way more so than much less performing tires.
I highly suggest you fellow 5 owners not ignore this advice.
